Введение
This guide will be utilized mainly if your CPU has gone bad and your laptop is essentially nonfunctional.
Выберете то, что вам нужно
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
8 человек успешно провели ремонт по этому руководству.
