Введение
By following the steps in this guide one should be able to replace the fan of a Dell Inspiron 7568 in under six minutes. The only tool necessary for this project is a Phillips #1 screwdriver.
Выберете то, что вам нужно
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Remove the four 3mm Phillips #1 screws holding the battery.
Unhinge the connector cable to the battery.
Remove the battery.
Begin by unclipping the cable connecting the fan and the motherboard.
Gently separate the motherboard cable from the clamp at the bottom of the fan.
Remove the cable.
Remove the two 3mm Phillips #1 screws that hold the fan into place.
Remove the fan.
3 человек успешно провели ремонт по этому руководству.
