Введение
This guide requires a Phillips #00 screwdriver
Выберете то, что вам нужно
Slide the battery-lock tab and hold.
Flip the battery away from the chassis to remove it.
Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
Fold the screen back to 180 degrees.
Using your index fingers, pull up the hinge cover.
After the hinges pop, pull the hinge cover gently.
Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
Tilt the keyboard away from the screen.
Pull up on the white tab underneath the keyboard to release the keyboard.
Еще один человек закончил это руководство.
