Введение
Guide to replace or upgrade the video card in your Dell Inspiron 9300
Выберете то, что вам нужно
Remove the battery prior to working on any internal components.
Remove the twelve 6mm Phillips screws from the bottom of the case.
Gently pry away the silver bezel above the keyboard and below the display using a spudger.
Remove the two 5mm Phillips screws retaining the keyboard.
Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
Gently pry the CMOS battery out of its retaining clip using a spudger.
Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
Remove the trackpad ribbon cable from the motherboard using a spudger.
Loosen the four 5mm Phillips screws holding the video card and heatsink in place
Еще один человек закончил это руководство.
1 Комментарий к руководству
This works only up to the point of pull up and away on the trackpad. The trackpad won't pull up.
