Dell Latitude E5450 Lower Case Replacement
Выберете то, что вам нужно
  1. Dell Latitude E5450 Lower Case Replacement, Unscrew the Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Remove the six Philips #0 screws from the lower case.
    • These screws are all 5.6 mm long, but it's still a good idea to keep track of them and make sure they go back in their proper holes!
  2. Dell Latitude E5450 Lower Case Replacement: шаг 2, изображение 1 из 1
    • This photo shows the location of the ten clips that hold the lower case in place. Take note of the location of the clips, and refer back to this step if your lower case gets stuck during removal.
    • Four clips hold the upper half of the case in place and can be released by prying around them with a spudger.
    • The other six clips along the bottom edge can not be released by prying at them. Instead, they come free by sliding the whole case upward, as shown in step 5 below.
  3. Dell Latitude E5450 Lower Case Replacement: шаг 3, изображение 1 из 2 Dell Latitude E5450 Lower Case Replacement: шаг 3, изображение 2 из 2
    • Insert the flat edge of a spudger into the small divot along the top edge of the case, just below the docking station port.
    • Pry up to release the two central clips along the upper edge of the case.
  4. Dell Latitude E5450 Lower Case Replacement: шаг 4, изображение 1 из 3 Dell Latitude E5450 Lower Case Replacement: шаг 4, изображение 2 из 3 Dell Latitude E5450 Lower Case Replacement: шаг 4, изображение 3 из 3
    • Use your spudger to pry up the remaining clips along the top edge.
  5. Dell Latitude E5450 Lower Case Replacement, Remove the Lower Case: шаг 5, изображение 1 из 3 Dell Latitude E5450 Lower Case Replacement, Remove the Lower Case: шаг 5, изображение 2 из 3 Dell Latitude E5450 Lower Case Replacement, Remove the Lower Case: шаг 5, изображение 3 из 3
    • Slide the lower case upward and remove it.
  6. Dell Latitude E5450 Lower Case Replacement: шаг 6, изображение 1 из 2 Dell Latitude E5450 Lower Case Replacement: шаг 6, изображение 2 из 2
    • When reinstalling the lower case, make sure you slide the bottom edge (the edge without the cutout) into place first before snapping the rest of the clips shut.
Заключение
Repair didn’t go as planned? Check out our Dell Latitude answers community for troubleshooting help.
Taylor Dixon
Участник с: 06/26/18
67 116 Репутация
Автор 94 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 1,505
