Dell Vostro 15 Memory Module Replacement
Выберете то, что вам нужно
  1. Dell Vostro 15 Memory Module Replacement, Battery: шаг 1, изображение 1 из 1
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
    Спросите у FixBot
    Добавить комментарий
  2. Dell Vostro 15 Memory Module Replacement, Hinge Cover: шаг 2, изображение 1 из 1
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
    Спросите у FixBot
  3. Dell Vostro 15 Memory Module Replacement, KeyBoard: шаг 3, изображение 1 из 1
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
    Спросите у FixBot
  4. Dell Vostro 15 Memory Module Replacement, Memory Module: шаг 4, изображение 1 из 1
    • Lift the memory module cover But Do Not Remove It.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    Спросите у FixBot
Заключение
Johnathan Hammond
Участник с: 02/28/18
46 149 Репутация
Автор 408 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
45 членов
Автор 2 003 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 28
За всё время: 295
