Введение
This guide helps you to upgrade or replace your wireless card to a new Wi-Fi standard if you have determined that the reason your wireless internet is not working is because of a hardware issue with the card.
Выберете то, что вам нужно
Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
Two 4.7mm Philips #1 screws
Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
One 3.9mm Phillips #1 screw
Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
Еще один человек закончил это руководство.
