Depth Sensor Node Streambed Installation Procedure
Выберете то, что вам нужно
  1. Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: шаг 1, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: шаг 1, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: шаг 1, изображение 3 из 3
    • Clear large rocks from the streambed to make it easier to install the strut channel.
    • Place cleared rocks downstream so they do not damage the node during a storm.
    • Set 5 ft steel strut channel into place.
    • Ensure the open side of the strut channel faces south so that the solar panel receives maximum sunlight! Addtionally, be careful not to deform the steel strut channel too much. A bit of deformation is okay.
    • Use the post pounder to drive the strut channel 3 ft into the stream bed.
    Спросите у FixBot
    Добавить комментарий
  2. Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: шаг 2, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: шаг 2, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: шаг 2, изображение 3 из 3
    • Place two spring strut channel nuts into the strut channel and then place the strut channel connector.
    • Two of the strut channel connector holes should be above the strut channel for connecting the top strut channel.
    • Insert two washers and screws into the nuts.
    Спросите у FixBot
  3. Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: шаг 3, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: шаг 3, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: шаг 3, изображение 3 из 3
    • This is what the attached strut channel connector looks like from above.
    • Place two additional spring strut channel nuts into the aluminum strut channel to be attached.
    • Insert the last two washers and screws into the nuts.
    • Use an impact driver to secure the screws into place. The impact driver should have a 3/4 '' Socket connected via a socket adapter.
    • Socket Adapter
    • This is what the extended strut channel looks like.
    Спросите у FixBot
  4. Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: шаг 4, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: шаг 4, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: шаг 4, изображение 3 из 3
    • Line up a 1 ft strut channel with a u-bracket to the vertical strut channel.
    • Put two spring strut channel nuts into the vertical strut channel. Insert two washers and screws into the u-bracket to hold the strut channel arm.
    • Use the impact driver to tighten the screws.
    • This is a what the final node holding structure looks like.
    Спросите у FixBot
  5. Depth Sensor Node Streambed Installation Procedure, Attaching the node: шаг 5, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching the node: шаг 5, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching the node: шаг 5, изображение 3 из 3
    • Place two screws into the node enclosure with the 5/16'' washer and strut channel nuts on the backside.
    • You can remove the strut channel nut spring to make installation easier.
    • Slide the node into the strut channel arm.
    • The washer should be on the outside of the strut channel and the strut channel nut should be on the inside.
    • Tighten the screws with a 3/8 inch wrench.
    Спросите у FixBot
  6. Depth Sensor Node Streambed Installation Procedure, Attaching the lock: шаг 6, изображение 1 из 1
    • Create a 4 number lock combination.
    • Projects have set lock combinations. Ask the lab for guidance.
    Спросите у FixBot
  7. Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: шаг 7, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: шаг 7, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: шаг 7, изображение 3 из 3
    • Using a tape measure, measure the length from the bottom of the ultrasonic depth sensor to the water surface.
    • Measure the length from the bottom of the ultrasonic depth sensor to the bottom of the stream bed.
    Спросите у FixBot
  8. Depth Sensor Node Streambed Installation Procedure, Trim foliage that may block solar panel: шаг 8, изображение 1 из 2 Depth Sensor Node Streambed Installation Procedure, Trim foliage that may block solar panel: шаг 8, изображение 2 из 2
    • If foliage may block the solar panel from charging, trim some branches.
    • This is a completely installed stream bed depth sensor node!
    Спросите у FixBot
  9. Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel arm: шаг 9, изображение 1 из 2 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel arm: шаг 9, изображение 2 из 2
    • Sometimes two strut channel arms are preferred over one.
    • Attach a second 1 ft strut channel arm using the same hardware as the first strut channel arm.
    • Use the node enclosure to determine how far apart the two arms need to be.
    • Tighten the screws with the impact drill.
    Спросите у FixBot
  10. Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: шаг 10, изображение 1 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: шаг 10, изображение 2 из 3 Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: шаг 10, изображение 3 из 3
    • Place four screws into the node enclosure with the washer and strut channel nuts on the backside.
    • This is what the node looks like attached to two strut channel arms.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Brooke Mason
Участник с: 05/29/19
2 958 Репутация
Автор 17 руководств
Команда
Open-Storm Участник Open-Storm
Community
14 членов
Автор 45 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 662
