Desktop PC Graphics Card Replacement
Выберете то, что вам нужно
  1. Desktop PC Graphics Card Replacement, Left Panel: шаг 1, изображение 1 из 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    Спросите у FixBot
    Добавить комментарий
  2. Desktop PC Graphics Card Replacement: шаг 2, изображение 1 из 2 Desktop PC Graphics Card Replacement: шаг 2, изображение 2 из 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    Спросите у FixBot
  3. Desktop PC Graphics Card Replacement, Graphics Card: шаг 3, изображение 1 из 1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
    Спросите у FixBot
  4. Desktop PC Graphics Card Replacement: шаг 4, изображение 1 из 2 Desktop PC Graphics Card Replacement: шаг 4, изображение 2 из 2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
    Спросите у FixBot
Заключение
86 человек успешно провели ремонт по этому руководству.
David Lennon
Участник с: 04/14/15
10 198 Репутация
Автор 10 руководств
Команда
Cal Poly, Team 4-5, Maness Spring 2015 Участник Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 членов
Автор 49 руководств
3 Комментарии к руководству
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Ons NA - Ответить Поделиться
I have a all in one pc so this is not relevant
Robert Campanelli - Ответить Поделиться
any diffrerences in slots?
benzy aceware - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 38
За последние 30 дней: 150
За всё время: 20,769
