DigMedia MusicStore CD-ROM Drive Replacement
Выберете то, что вам нужно
  1. DigMedia MusicStore CD-ROM Drive Replacement, Remove screws: шаг 1, изображение 1 из 1
    • Remove six Philips #2 screws from the bottom of the case.
    • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
    Спросите у FixBot
    Добавить комментарий
  2. DigMedia MusicStore CD-ROM Drive Replacement, Disconnect top cover ribbon cable: шаг 2, изображение 1 из 1
    • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
    • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
    • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
    Спросите у FixBot
  3. DigMedia MusicStore CD-ROM Drive Replacement, Remove RF shield: шаг 3, изображение 1 из 2 DigMedia MusicStore CD-ROM Drive Replacement, Remove RF shield: шаг 3, изображение 2 из 2
    • Simply lift the RF shield off the unit.
    • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
    Спросите у FixBot
  4. DigMedia MusicStore CD-ROM Drive Replacement, CD-ROM cables and screws: шаг 4, изображение 1 из 1
    • Disconnect the digital audio connector (red) and the lid switch return connector (blue) from the logic board.
    • Unscrew four Philips #2 screws that secure the CD-ROM drive to the chassis.
    Спросите у FixBot
  5. DigMedia MusicStore CD-ROM Drive Replacement, Data and Power cables: шаг 5, изображение 1 из 1
    • Disconnect the large 40-pin IDE data connector and disconnect the 4-pin PC power connector from the CD-ROM drive.
    Спросите у FixBot
  6. DigMedia MusicStore CD-ROM Drive Replacement, Remove CD-ROM: шаг 6, изображение 1 из 1
    • Lift the CD-ROM drive out of the chassis.
    Спросите у FixBot
Заключение
Matt Falcon
Участник с: 05/09/15
2 773 Репутация
Автор 14 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 239
