Disassembling ASUS K501U
Выберете то, что вам нужно
    1. Disassembling ASUS K501U, ASUS K501U: шаг 1, изображение 1 из 1
      • Place as shown in the photo with the screen hinge at the top. Remove all ten screws from the bottom cover. These screws have different length - longest at the top and shortest at the bottom. I color-coded screws with similar length in red, yellow and green. Make sure to install them correctly when you assemble the laptop back together.
      • Remove the four 10.7mm-long screws along the top edge.
      • Remove the two 6.7mm-long screws along the sides.
      • Remove the four 4.7mm-long screws along the bottom edge.
      Спросите у FixBot
      Добавить комментарий
    2. Disassembling ASUS K501U: шаг 2, изображение 1 из 1
      • The bottom cover is held in place by plastic tabs along the outside edges. Using a plastic pry tool, carefully separate the bottom cover from the palmrest assembly and remove it.
      Спросите у FixBot
    3. Disassembling ASUS K501U: шаг 3, изображение 1 из 1
      • The battery is connected to the motherboard via a cable.
      • Remove the four 4.7mm-long screws securing the battery.
      Спросите у FixBot
    4. Disassembling ASUS K501U: шаг 4, изображение 1 из 1
      • In order to unlock the battery connector you’ll have to slide the metal bracket to the shown direction.
      Спросите у FixBot
    5. Disassembling ASUS K501U: шаг 5, изображение 1 из 1
      • Carefully lift up the battery cable from the connector.
      • Do not use metal objects to lift up the cable. You can short metal pins inside. It is recommended that you use a plastic spudger.
      Спросите у FixBot
    6. Disassembling ASUS K501U: шаг 6, изображение 1 из 1
      • You can find a new replacement battery using the part number printed on the original battery. I would recommend using a genuine Asus battery, not a third-party replacement. Replacement battery model B31N1429.
      Спросите у FixBot
    7. Disassembling ASUS K501U: шаг 7, изображение 1 из 1
      • Asus K501U motherboard has only one memory slot. Some memory is built into the motherboard. You can access the available slot if you remove the metal cover. You can install up to 8GB DDR3-12800 SODIMM RAM module into this slot.
      Спросите у FixBot
    8. Disassembling ASUS K501U: шаг 8, изображение 1 из 1
      • Remove four 4.7mm-long screws from the hard drive caddy and remove the caddy. This laptop came with a m.2 solid state drive so there is no regular 2.5″ hard drive installed.
      Спросите у FixBot
    9. Disassembling ASUS K501U: шаг 9, изображение 1 из 1
      • Remove one screw securing the solid state drive and pull the drive out. This is m.2 SATA III solid state drive (not NVMe).
      Спросите у FixBot
    10. Disassembling ASUS K501U: шаг 10, изображение 1 из 1
      • Remove three screws securing the right fan.
      • Disconnect fan cable from the motherboard.
      Спросите у FixBot
    11. Disassembling ASUS K501U: шаг 11, изображение 1 из 1
      • Remove the right fan.
      Спросите у FixBot
    12. Disassembling ASUS K501U: шаг 12, изображение 1 из 1
      • Remove three screws securing the left fan.
      Спросите у FixBot
    13. Disassembling ASUS K501U: шаг 13, изображение 1 из 1
      • Remove the left fan.
      Спросите у FixBot
    14. Disassembling ASUS K501U: шаг 14, изображение 1 из 1
      • The USB audio board is mounted under the right hinge.
      • Remove three screws from the right hinge. Remove one screw from the board.
      • Disconnect the USB audio board cable (color-coded in green).
      • Disconnect the right speaker cable (color-coded in yellow).
      Спросите у FixBot
    15. Disassembling ASUS K501U: шаг 15, изображение 1 из 1
      • Unlock the connector first by lifting up the locking tab.
      • After that pull the cable out.
      Спросите у FixBot
    16. Disassembling ASUS K501U: шаг 16, изображение 1 из 1
      • Lift up the right hinge and remove the USB audio board.
      Спросите у FixBot
    17. Disassembling ASUS K501U: шаг 17, изображение 1 из 1
      • Carefully disconnect wireless antenna cables from the wireless card.
      Спросите у FixBot
    18. Disassembling ASUS K501U: шаг 18, изображение 1 из 1
      • Remove one 4.7mm-long screw securing the wireless card.
      • Pull out the wireless card in the direction shown.
      Спросите у FixBot
    19. Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
tqd
Участник с: 04/09/25
3 297 Репутация
Автор 17 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 25
За последние 30 дней: 141
За всё время: 2,008
