Выберете то, что вам нужно
Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
Remove the batteries from the battery compartment located on the underside of the camera.
Remove the SD card from the compartment located on the flat, left side of the camera.
Separate the front and the back pieces of the camera's plastic casing using a spudger.
When separating the small silver siding, the indicator for the view/off/playback may fall out.
The plastic viewing window located on the top of the camera may also become lose and fall out.
Optional: Remove two black screws from top of camera on the flash side for more working space.
Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
Connect new flash by soldering copper ends to their respective ends to new flash element.
