Disassembling External Storage Hard drive
Выберете то, что вам нужно
  1. Disassembling External Storage Hard drive, Disassembling External Storage Hard drive: шаг 1, изображение 1 из 1
    • Remove the screw marked with a red arrow to access hidden top tab.
    • Use a pointy tool to press the two tabs around the USB 3 connector. These are accessible via the holes marked with orange arrows.
    • You can slightly lift the back edge up to help free the tabs as you press them in. It doesn't take much to release them, so don't push too hard.
    Спросите у FixBot
    Добавить комментарий
  2. Disassembling External Storage Hard drive: шаг 2, изображение 1 из 2 Disassembling External Storage Hard drive: шаг 2, изображение 2 из 2
    • Along the top edge are the tabs marked in the first picture by the red circles. Use a thin-bladed screw driver to catch and pull back these tabs slightly to release the cover on this edge.
    • Lift on the cover slightly to ensure the tabs are released.
    Спросите у FixBot
  3. Disassembling External Storage Hard drive: шаг 3, изображение 1 из 2 Disassembling External Storage Hard drive: шаг 3, изображение 2 из 2
    • The front of the case has two tabs, marked by red arrows in the first pic. Repeat the process of using the screwdriver to gently release the tabs.
    • Continuing gently lifting on the cover while releasing the hidden tabs.
    Спросите у FixBot
  4. Disassembling External Storage Hard drive: шаг 4, изображение 1 из 1
    • The 3 red arrows indicate the hidden tabs on the last side. Repeat the screwdriver technique from the last two steps.
    • You should be able to remove the cover after all tabs have been released.
    Спросите у FixBot
  5. Disassembling External Storage Hard drive: шаг 5, изображение 1 из 2 Disassembling External Storage Hard drive: шаг 5, изображение 2 из 2
    • With the cover removed, the hard drive should be exposed--refer to the first picture to locate it.
    • Use the flat blade screwdriver to gently pry out the plastic case the hard drive sits in.
    • The hard drive is only held in the case with rubber bumper style mounts, and will come out with a little finger pulling.
    Спросите у FixBot
  6. Disassembling External Storage Hard drive: шаг 6, изображение 1 из 3 Disassembling External Storage Hard drive: шаг 6, изображение 2 из 3 Disassembling External Storage Hard drive: шаг 6, изображение 3 из 3
    • Remove hard drive from plastic case, flip over, and remove the two screws marked by red circles.
    • You will be left with the board and interface (seen in 3rd pic), ready to install your new hard drive.
    • Installation is the reverse of removal! Enjoy!
    Спросите у FixBot
Заключение
10 человек успешно провели ремонт по этому руководству.
HWgeek
Участник с: 12/03/12
307 Репутация
1 руководство автора
5 Комментарии к руководству
Nice, easy and concise ‘how-to’. You made my task so much easier. Thank you!
Brian Puffer - Ответить Поделиться
Thanks..got the job done.
Jeff Willard - Ответить Поделиться
thank you for the blog. keep it up.
Sunil Das Shrestha - Ответить Поделиться
thanks.... just the job.
Stephen Foxall - Ответить Поделиться
My God I would never have been able to get this thing apart intact without this guide, THANKS !!
James McCarthy - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 23
За последние 30 дней: 132
За всё время: 24,793
