Disassembling IBM WorkPad c3 LCD
Выберете то, что вам нужно
    1. Disassembling IBM WorkPad c3 LCD, Back Case: шаг 1, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD, Back Case: шаг 1, изображение 2 из 2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      Спросите у FixBot
      Добавить комментарий
    2. Disassembling IBM WorkPad c3 LCD: шаг 2, изображение 1 из 1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      Спросите у FixBot
    3. Disassembling IBM WorkPad c3 LCD: шаг 3, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD: шаг 3, изображение 2 из 2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      Спросите у FixBot
    1. Disassembling IBM WorkPad c3 LCD, Front Case: шаг 4, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD, Front Case: шаг 4, изображение 2 из 2
      • Turn the device over, so that the screen is laying on a flat surface.
      Спросите у FixBot
    2. Disassembling IBM WorkPad c3 LCD: шаг 5, изображение 1 из 3 Disassembling IBM WorkPad c3 LCD: шаг 5, изображение 2 из 3 Disassembling IBM WorkPad c3 LCD: шаг 5, изображение 3 из 3
      • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
      • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
      • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
      Спросите у FixBot
    3. Disassembling IBM WorkPad c3 LCD: шаг 6, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD: шаг 6, изображение 2 из 2
      • The device will be extremely hot. Use a towel or oven mitt to grab it.
      • Using the Plastic Opening Tools, take the front of the case off.
      • If the case is difficult to remove, try repeating step 2.
      • The power button at the top of the device will be loose once the front part of the case is removed.
      Спросите у FixBot
    1. Disassembling IBM WorkPad c3 LCD, Battery: шаг 7, изображение 1 из 1
      • Remove the yellow tape that is covering the battery connector
      Спросите у FixBot
    2. Disassembling IBM WorkPad c3 LCD: шаг 8, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Using the tweezers, carefully disconnect the battery cable from the port
      Спросите у FixBot
    3. Disassembling IBM WorkPad c3 LCD: шаг 9, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD: шаг 9, изображение 2 из 2
      • Using the plastic opening tools, lift the battery out of the case
      • The battery is secured with adhesive and it will take some effort to remove
      Спросите у FixBot
    1. Disassembling IBM WorkPad c3 LCD, LCD: шаг 10, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD, LCD: шаг 10, изображение 2 из 2
      • Using the spudger lift the tabs holding the LCD/Digitizer combo cables to the WorkPad.
      Спросите у FixBot
    2. Disassembling IBM WorkPad c3 LCD: шаг 11, изображение 1 из 2 Disassembling IBM WorkPad c3 LCD: шаг 11, изображение 2 из 2
      • Using your thumb, press down gently on the back of the LCD.
      • The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
      Спросите у FixBot
Заключение
Emily Falkenstein
Участник с: 10/05/10
75 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 21-35, Regan Fall 2010 Участник Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 членов
Автор 40 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 42
За всё время: 2,365
