Disassembling Motorola i265 Rear Casing/Battery/SIM Card
Выберете то, что вам нужно
  1. Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: шаг 1, изображение 1 из 2 Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: шаг 1, изображение 2 из 2
    • Press thumb against the top of the rear casing as shown and push down as you slide the casing off of the body.
    • You should hear a click as the latches on the casing disengage.
    Спросите у FixBot
    Добавить комментарий
  2. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: шаг 2, изображение 1 из 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: шаг 2, изображение 2 из 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: шаг 2, изображение 3 из 3
    • To remove the battery, press thumb against the bottom edge of the battery and push towards the top of the phone.
    • Then, lift the bottom edge of the battery upwards out of the body. Gently pull the battery towards yourself, and out of the phone.
    Спросите у FixBot
  3. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: шаг 3, изображение 1 из 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: шаг 3, изображение 2 из 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: шаг 3, изображение 3 из 3
    • To remove SIM card, press thumb against tab marked “PUSH.”
    • While still pressing the PUSH tab, gently press spduger into the groove between the top of the SIM card and the body. Use spudger to slide SIM card toward the PUSH tab, so that when the spudger reaches the metal cover, the card itself is depressing the tab.
    • Press your thumb against the exposed section of the SIM card, and slide it towards the rear of the phone until it is completely free of the metal cover.
    Спросите у FixBot
Заключение
Jonathan Uder
Участник с: 04/15/10
1 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 6-15, Maness Spring 2010 Участник Cal Poly, Team 6-15, Maness Spring 2010
CPSU-MANESS-S10S6G15
4 членов
Автор 9 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 36
За всё время: 2,887
