Выберете то, что вам нужно
There are four screws hidden under the back two skates. You do not need to remove the front one. I used a razor blade to carefully lift the pads without touching the adhesive too much. If they get dirty, you may need to replace them.
There are two #1 Phillips screws under the main pad and two #0 Phillips screws under the thumb wing.
The back is now loose. Carefully start to pry it open, using a thin spudger or plastic card to the clips on the front.
There is one clip on near the USB-C port.
There are two clips just in front of the thumb. These are difficult to remove and require pulling the vertical silver piece out while slipping the bottom down.
To reassemble your device, follow these instructions in reverse order. Be sure to keep your mouse skates clean or you may have to replace them.
