Выберете то, что вам нужно
First, gather all necessary tools.
Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
Slide the back cover downwards off of the phone while pressing down on the tab.
Locate the bottom-left corner of the phone where there is a spot to remove the battery.
To remove the top of the back cover, pry the sides and pop it off.
Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
Take off the casing and keyboard.
Remove the screws while holding the screen in place using a Torx T6 screwdriver.
Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
Lift the ribbon, disconnecting contact with the motherboard.
Gently pull the screen off of the phone.
Be sure not to rip the sticker that connects the display and the motherboard.
Pull the silver case off to completely free the cracked or damaged screen.
The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
