Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017)
Выберете то, что вам нужно
    1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: шаг 1, изображение 1 из 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: шаг 1, изображение 2 из 2
      • Plastic spudgers/opening tools
      • T2 Torx Screwdriver
      Спросите у FixBot
      Добавить комментарий
    2. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the battery compartment: шаг 2, изображение 1 из 1
      • Use a narrow-tipped object (such as a ballpoint pen or the tip of the T2 Torx Screwdriver) to depress the dimple on the battery compartment to release it
      • Replacement batteries are two (2) CR 2032 coin cell batteries.
      Спросите у FixBot
    3. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: шаг 3, изображение 1 из 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: шаг 3, изображение 2 из 2
      • Gently pry along the edges of the remote using your fingers and prying tools to release the plastic clips.
      • It works best to start from the battery compartment and slowly work your way up to the top of the remote where the IR blaster is located.
      • Once the plastic clips are released, there is adhesive along the length of the volume sensor bar holding the front face in place. Slowly pry the face away from the rest of the remote and adjust your grip to avoid snapping the thin plastic face.
      Спросите у FixBot
    4. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: шаг 4, изображение 1 из 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: шаг 4, изображение 2 из 2
      • There are (6) T2 Torx screws holding the mainboard to the frame of the remote.
      • Two clips hold the mainboard in place. Slightly lift the top of the mainboard up and slide it towards the top of the remote to remove it from the frame.
      Спросите у FixBot
    5. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: шаг 5, изображение 1 из 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: шаг 5, изображение 2 из 2
      • The remote should now be fully disassembled.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Skeven
Участник с: 04/21/25
152 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 57
За всё время: 535
