Disassembling Samsung SyncMaster 205BW Monitor
Выберете то, что вам нужно
    1. Disassembling Samsung SyncMaster 205BW Monitor, Disassembling Samsung SyncMaster 205BW Monitor: шаг 1, изображение 1 из 1
      • Back of the monitor. Remove the two screws at the top of the stand.
      Спросите у FixBot
      Добавить комментарий
    2. Disassembling Samsung SyncMaster 205BW Monitor: шаг 2, изображение 1 из 1
      • Stand and monitor body now separated.
      Спросите у FixBot
    3. Disassembling Samsung SyncMaster 205BW Monitor: шаг 3, изображение 1 из 1
      • Front of monitor body. Push on the silver edge to unhook it from the panel.
      Спросите у FixBot
    4. Disassembling Samsung SyncMaster 205BW Monitor: шаг 4, изображение 1 из 1
      • Silver edge cover unlocked. Note that a cable connects to the body. Hold the panel and remove the black cover at the back. You can then disconnect the cable.
      Спросите у FixBot
    5. Disassembling Samsung SyncMaster 205BW Monitor: шаг 5, изображение 1 из 1
      • Silver edge removed and placed under the body with metal back. Black cover removed. The front panel cable connects to the bottom right of the body. Remove it. Remove the metal cover on top right by pulling it slightly on the edge at the top. This allows the two hooks on the slanting edge of the metal bracket to be unhooked.
      Спросите у FixBot
    6. Disassembling Samsung SyncMaster 205BW Monitor: шаг 6, изображение 1 из 1
      • Remove the cover on the right to reveal two cables with four connectors. There is also a connector under the air holes which is now shown above the bracket with words "LVDS". Remove them all to free the metal bracket with the circuit boards from the panel.
      Спросите у FixBot
    7. Disassembling Samsung SyncMaster 205BW Monitor: шаг 7, изображение 1 из 1
      • The metal bracket with circuit boards. The smaller circuit board: * two screws (bottom left, bottom right) * four screw extenders at the sides of the connectors The larger circuit board: * two black screws (bottom left, top middle) * one silver screw with washer that holds a metal strip and circuit board (top left)
      Спросите у FixBot
    8. Disassembling Samsung SyncMaster 205BW Monitor: шаг 8, изображение 1 из 1
      • Circuit board with unfastened screws pointing to the holes they were in.
      Спросите у FixBot
    9. Disassembling Samsung SyncMaster 205BW Monitor: шаг 9, изображение 1 из 1
      • Disassembled pieces.
      Спросите у FixBot
    10. Disassembling Samsung SyncMaster 205BW Monitor: шаг 10, изображение 1 из 1
      • Circuit boards zoomed in.
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
YIP Chi Lap
Участник с: 04/22/11
282 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 67
За всё время: 9,359
