Dragon Touch M10X Screen Replacement
Выберете то, что вам нужно
    1. Dragon Touch M10X  Screen Replacement, Screen: шаг 1, изображение 1 из 2 Dragon Touch M10X  Screen Replacement, Screen: шаг 1, изображение 2 из 2
      • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
      Спросите у FixBot
      Добавить комментарий
    2. Dragon Touch M10X  Screen Replacement: шаг 2, изображение 1 из 1
      • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
      • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
      Спросите у FixBot
    3. Dragon Touch M10X  Screen Replacement: шаг 3, изображение 1 из 2 Dragon Touch M10X  Screen Replacement: шаг 3, изображение 2 из 2
      • Using your hands and the separating tool, remove the back cover from the device.
      Спросите у FixBot
    4. Dragon Touch M10X  Screen Replacement: шаг 4, изображение 1 из 2 Dragon Touch M10X  Screen Replacement: шаг 4, изображение 2 из 2
      • Using a J0 phillips head bit, remove the four 1mm screws from the speaker cover. Remove the cover and all four screws.
      Спросите у FixBot
    5. Dragon Touch M10X  Screen Replacement: шаг 5, изображение 1 из 1
      • Using a plastic opening tool, carefully peel off the yellow tape holding the battery in place.
      Спросите у FixBot
    6. Dragon Touch M10X  Screen Replacement: шаг 6, изображение 1 из 1
      • The battery is held onto the surface with a strong epoxy. The battery can be bent easily so extreme care must be taken in removing it from the surface. A plastic opening tool must be used to loosen the battery from the surface.
      • Once it is loose, it may be fully separated by using either your hands or the plastic opening tool.
      Спросите у FixBot
    7. Dragon Touch M10X  Screen Replacement: шаг 7, изображение 1 из 2 Dragon Touch M10X  Screen Replacement: шаг 7, изображение 2 из 2
      • Using a J0 phillips head bit unscrew the three 1 mm screws from the motherboard as shown. Remove all three and place them aside.
      Спросите у FixBot
    8. Dragon Touch M10X  Screen Replacement: шаг 8, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Using a plastic opening tool, lift up the latch that secures the right side of the motherboard to the screen's ribbon cable.
      • Using tweezers remove the screen's ribbon cable from the motherboard.
      Спросите у FixBot
    9. Dragon Touch M10X  Screen Replacement: шаг 9, изображение 1 из 1
      • Using a plastic opening tool, lift up the latch that secures the left side of the motherboard to the screen's ribbon cable.
      Спросите у FixBot
    10. Dragon Touch M10X  Screen Replacement: шаг 10, изображение 1 из 1
      • Completely remove the conjoined battery, speakers, and motherboard from the device.
      Спросите у FixBot
    11. Dragon Touch M10X  Screen Replacement: шаг 11, изображение 1 из 1
      • Once all components have been cleared out, you can pry the corners of the device screen away from the LCD panel using a plastic opening tool. Work your way around until it is loose enough to remove.
      Спросите у FixBot
    12. Dragon Touch M10X  Screen Replacement: шаг 12, изображение 1 из 1
      • Remove the LCD panel from the device screen.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Eric Megna
Участник с: 03/24/16
333 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 4-7, Catania Spring 2016 Участник UMass Dartmouth, Team 4-7, Catania Spring 2016
UMASSD-CATANIA-S16S4G7
3 членов
Автор 8 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 37
За всё время: 4,628
