Введение
The motor inside the barrel of the gun powers the fan. Use this guide to replace the motor.
Выберете то, что вам нужно
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Remove the plastic cap from the motor,
This will allow you to work only with the motor and fan.
Еще один человек закончил это руководство.
