DualSense Edge Front Microphone Replacement
Выберете то, что вам нужно
  1. DualSense Edge Front Microphone Replacement, Remove the front trim: шаг 1, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the front trim: шаг 1, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the front trim: шаг 1, изображение 3 из 3
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
  2. DualSense Edge Front Microphone Replacement, Remove the joysticks: шаг 2, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the joysticks: шаг 2, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the joysticks: шаг 2, изображение 3 из 3
    • Flip the controller over so the joysticks are facing up.
    • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
    • Slide the joystick out from its slot.
  3. DualSense Edge Front Microphone Replacement: шаг 3, изображение 1 из 1
    • Repeat this process to remove the other joystick.
  4. DualSense Edge Front Microphone Replacement, Insert an opening pick: шаг 4, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Insert an opening pick: шаг 4, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Insert an opening pick: шаг 4, изображение 3 из 3
    • The rear trim is held in place by fragile plastic clips. Work slowly and gently to avoid breaking the clips.
    • If you installed the back button paddles included with your controller, remove them before beginning this process.
    • Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
    • Slide the opening pick towards the bottom of the grip to release the clips.
  5. DualSense Edge Front Microphone Replacement, Release the clips: шаг 5, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Release the clips: шаг 5, изображение 2 из 2
    • Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
    • Slide the opening pick around the edge of the rear trim to release the clips.
  6. DualSense Edge Front Microphone Replacement, Remove the rear trim: шаг 6, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the rear trim: шаг 6, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the rear trim: шаг 6, изображение 3 из 3
    • Slide the opening along the edge of the trim on the other grip.
    • Once all clips are released, remove the trim.
    • If at any point the trim feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
  7. DualSense Edge Front Microphone Replacement, Remove the L1 and R1 buttons: шаг 7, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the L1 and R1 buttons: шаг 7, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the L1 and R1 buttons: шаг 7, изображение 3 из 3
    • The L1 and R1 buttons are held in by two clips. If only one clip releases, move your spudger to the other side of the button to release the remaining clip. Don't continue prying on one side after a clip is released, or you risk breaking the other clip.
    • Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
    • Use the spudger to pry out the L1 button.
    • The buttons tend to shoot out in this step. You can place your thumb over the button to prevent this.
    • Repeat this process to remove the R1 button.
  8. DualSense Edge Front Microphone Replacement, Remove the screws: шаг 8, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the screws: шаг 8, изображение 2 из 2
    • Remove the two 6.4 mm screws behind the L1 and R1 buttons.
    • Use a JIS J0 driver or an official iFixit Phillips PH0 driver, which is designed to be cross-compatible with JIS screws. Using a screwdriver other than an official iFixit driver or a JIS driver may result in stripped screws.
  9. DualSense Edge Front Microphone Replacement, Lift the release bar spring: шаг 9, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Lift the release bar spring: шаг 9, изображение 2 из 2
    • Rotate the controller so the grips are pointing towards you.
    • Use a pair of angled tweezers to lift the right end of the release bar spring off of the white post.
    • The spring is located below the RB button.
  10. DualSense Edge Front Microphone Replacement, Remove the trim release bar: шаг 10, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the trim release bar: шаг 10, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the trim release bar: шаг 10, изображение 3 из 3
    • Use a pair of tweezers or your fingers to slide the release bar to the left.
    • Slide the release bar away from the controller to remove it.
  11. DualSense Edge Front Microphone Replacement, Remove the rear case screws: шаг 11, изображение 1 из 1
    • Remove the nine screws securing the rear case:
    • Seven 6.4 mm‑long screws
    • Two 10.5 mm‑long screws
  12. DualSense Edge Front Microphone Replacement, Insert an opening pick: шаг 12, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Insert an opening pick: шаг 12, изображение 2 из 2
    • Insert the point an opening pick in the gap along the outside edge of one of the controller grips, near the bottom.
  13. DualSense Edge Front Microphone Replacement, Separate the rear case: шаг 13, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Separate the rear case: шаг 13, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Separate the rear case: шаг 13, изображение 3 из 3
    • Pry with the opening pick to separate the rear case from the front case by releasing the clips that hold them together.
    • Continue prying along the edge of the controller until one side is separated.
  14. DualSense Edge Front Microphone Replacement: шаг 14, изображение 1 из 2 DualSense Edge Front Microphone Replacement: шаг 14, изображение 2 из 2
    • Repeat this process to separate the other side of the rear case.
  15. DualSense Edge Front Microphone Replacement, Remove the rear case: шаг 15, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the rear case: шаг 15, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the rear case: шаг 15, изображение 3 из 3
    • If at any point the case feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
    • Hold the main body of the controller with one hand.
    • Lift the rear case with your other hand. It should lift at an angle.
    • Pushing slightly towards the L and R buttons, lift the rear case off of the controller and remove it.
    • During reassembly, make sure the plastic covers for the adaptive trigger assembly adjustment sliders are correctly installed over the sliders.
  16. DualSense Edge Front Microphone Replacement, Replace the slider covers: шаг 16, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Replace the slider covers: шаг 16, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Replace the slider covers: шаг 16, изображение 3 из 3
    • The rear case holds two small plastic covers for the adaptive trigger assembly adjustment sliders. These may have come off during removal. Place them back in the rear cover now to avoid losing them.
    • Use a pair of tweezers or your fingers to lift the cover from the controller.
    • Slide the flat end of the cover under the plastic tab in the rear case.
    • Make sure it is placed so it can move freely in its groove. The edge with the notch should be towards the middle of the controller.
    • If a cover got bent during the rear case removal or reassembly process, apply a small amount of heat with a hair dryer to restore it to its original shape.
    • During reassembly, you can use a small piece of painter's tape on the outside of the rear case to hold the covers in place.
  17. DualSense Edge Front Microphone Replacement, Lift the battery: шаг 17, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Lift the battery: шаг 17, изображение 2 из 2
    • If your battery is swollen or deformed in any way, take appropriate precautions.
    • Lift the battery and move it to the right, so the connector underneath the battery is accessible.
  18. DualSense Edge Front Microphone Replacement, Disconnect the battery: шаг 18, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Disconnect the battery: шаг 18, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Disconnect the battery: шаг 18, изображение 3 из 3
    • Use the flat end of a spudger to pry up the low profile connector.
    • Only pry on the connector. Do not pry on the wires, as that may damage the wires.
    • Remove the battery.
  19. DualSense Edge Front Microphone Replacement, Move the vibration motor cable: шаг 19, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Move the vibration motor cable: шаг 19, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Move the vibration motor cable: шаг 19, изображение 3 из 3
    • This procedure is written using the R2 trigger assembly, which is on your left. The procedure to remove the L2 assembly is identical.
    • Use a pair of tweezers to disconnect the vibration motor cable by lifting the JST connector out of its socket.
    • This cable is connected to the back button board, between the RB or LB button and the vibration motor.
    • Continue lifting until the vibration motor cable is free of the clip on the trigger assembly.
  20. DualSense Edge Front Microphone Replacement, Remove the trigger assembly screws: шаг 20, изображение 1 из 1
    • Remove the two 6.4 mm‑long screws securing the trigger assembly.
  21. DualSense Edge Front Microphone Replacement, Lift the trigger assembly: шаг 21, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Lift the trigger assembly: шаг 21, изображение 2 из 2
    • Lift the trigger assembly away from the controller and hold it so you can access the ribbon cable underneath it.
    • Do not try to fully remove the trigger assembly yet. It's still connected by a ribbon cable, which you'll disconnect in the next step
  22. DualSense Edge Front Microphone Replacement, Disconnect the trigger assembly: шаг 22, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Disconnect the trigger assembly: шаг 22, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Disconnect the trigger assembly: шаг 22, изображение 3 из 3
    • While holding the trigger assembly above the controller, use a pair of tweezers to disconnect the trigger assembly ribbon cable by gripping the pull tab and pulling away from the connector.
    • Remove the trigger assembly
  23. DualSense Edge Front Microphone Replacement, Remove the R back button ribbon cable: шаг 23, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the R back button ribbon cable: шаг 23, изображение 2 из 2
    • Make sure you removed both the L2 and the R2 adaptive trigger assemblies before continuing.
    • Use a pair of tweezers to disconnect the RB back button ribbon cable connector from the motherboard by griping the blue tab on the ribbon cable and pulling away from the connector.
    • The RB back button has an "R" engraved on the bracket and it's to your left.
  24. DualSense Edge Front Microphone Replacement: шаг 24, изображение 1 из 2 DualSense Edge Front Microphone Replacement: шаг 24, изображение 2 из 2
    • Use a pair of tweezers to move the RB back button ribbon cable out from its plastic clip.
  25. DualSense Edge Front Microphone Replacement: шаг 25, изображение 1 из 2 DualSense Edge Front Microphone Replacement: шаг 25, изображение 2 из 2
    • Use a pair of tweezers to disconnect the RB back button ribbon cable from the back button board.
  26. DualSense Edge Front Microphone Replacement, Remove the rear microphone: шаг 26, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the rear microphone: шаг 26, изображение 2 из 2
    • Use a pair of tweezers to disconnect the rear microphone ribbon cable from the motherboard.
    • Continue lifting to remove the microphone.
    • During reassembly, make sure to slot the plastic on the right edge of the microphone into the bracket on the microphone housing.
  27. DualSense Edge Front Microphone Replacement, Disconnect the L back button: шаг 27, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Disconnect the L back button: шаг 27, изображение 2 из 2
    • Use a pair of tweezers to disconnect the LB back button ribbon cable from the motherboard by gripping the blue tab and pulling away from the connector.
  28. DualSense Edge Front Microphone Replacement, Remove the battery bracket screws: шаг 28, изображение 1 из 1
    • Remove the three screws securing the battery bracket:
    • Two 6.4 mm‑long screws near the middle of the left and right edges of the battery bracket
    • One 10.4 mm‑long screw near the center of the battery bracket
  29. DualSense Edge Front Microphone Replacement, Remove the battery bracket: шаг 29, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the battery bracket: шаг 29, изображение 2 из 2
    • Lift and remove the battery bracket.
  30. DualSense Edge Front Microphone Replacement, Disconnect the front microphone ribbon cable: шаг 30, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Disconnect the front microphone ribbon cable: шаг 30, изображение 2 из 2
    • Use a pair of tweezers to disconnect the front microphone ribbon cable from the motherboard by gripping the blue pull tab and pulling away from the connector.
    • The front microphone connector is below LB back button connector, at the bottom of the motherboard.
  31. DualSense Edge Front Microphone Replacement, Disconnect the touchpad ribbon cable: шаг 31, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Disconnect the touchpad ribbon cable: шаг 31, изображение 2 из 2
    • Use a pair of tweezers to disconnect the touchpad ribbon cable from the motherboard by gripping the blue pull tab and pulling away from the connector.
    • This connector can be difficult to disconnect. If you grip the pull tab by the sides, as shown in the picture, squeeze just hard enough to grip the tab to avoid bending the tab and ribbon cable.
  32. DualSense Edge Front Microphone Replacement, Remove the motherboard: шаг 32, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the motherboard: шаг 32, изображение 2 из 2
    • Insert the flat end of a spudger underneath the motherboard, below the USB-C port.
    • Use the spudger to lift the motherboard free of the small clips that secure it.
  33. DualSense Edge Front Microphone Replacement: шаг 33, изображение 1 из 2 DualSense Edge Front Microphone Replacement: шаг 33, изображение 2 из 2
  34. DualSense Edge Front Microphone Replacement, Remove the speaker: шаг 34, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the speaker: шаг 34, изображение 2 из 2
    • Use tweezers or your fingers to lift and remove the speaker from the center of the midframe.
    • During reassembly:
    • Check that your new speaker has a piece of foam on the back. If it doesn't, transfer the foam from the old speaker to the new one.
    • Install the speaker so the raised portion of the contact springs are to the right. If you are unsure of the correct orientation, check the motherboard and make sure the springs make contact with the posts on the motherboard.
  35. DualSense Edge Front Microphone Replacement, Remove the midframe: шаг 35, изображение 1 из 1
    • Remove the five screws securing the midframe:
    • Three 6.4 mm‑long screws
    • Two 10.4 mm‑long screws
  36. DualSense Edge Front Microphone Replacement: шаг 36, изображение 1 из 2 DualSense Edge Front Microphone Replacement: шаг 36, изображение 2 из 2
    • Grab the vibration motor housings and lift the midframe to remove it.
    • Make sure the touchpad cable slides freely through the opening in the midframe.
  37. DualSense Edge Front Microphone Replacement, Remove the mute button: шаг 37, изображение 1 из 2 DualSense Edge Front Microphone Replacement, Remove the mute button: шаг 37, изображение 2 из 2
    • Use angled tweezers to grab and remove the Mute button, which is located along the bottom edge of the center of the midframe.
    • During reassembly, insert the Mute button so the edge with the slot for the clip is towards the top of the controller.
  38. DualSense Edge Front Microphone Replacement, Remove the front microphone: шаг 38, изображение 1 из 3 DualSense Edge Front Microphone Replacement, Remove the front microphone: шаг 38, изображение 2 из 3 DualSense Edge Front Microphone Replacement, Remove the front microphone: шаг 38, изображение 3 из 3
    • Use a pair of tweezers to grab the front microphone ribbon cable.
    • Remove the ribbon cable from its routing channel and remove the front microphone.
    • During reassembly, make sure to slot the front microphone over the plastic tab on the front of the midframe before re-routing the ribbon cable.
Заключение
Spencer Pennington
Участник с: 09/09/23
23 584 Репутация
Автор 125 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 15 957 руководств
1 Комментарий к руководству
Where i could find the front ribbon mic replacement part?
duanra alive - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 22
За последние 30 дней: 109
За всё время: 962
