EasySMX X15 Main Board Replacement
Выберете то, что вам нужно
  1. EasySMX X15 Main Board Replacement, Bottom Casing: шаг 1, изображение 1 из 2 EasySMX X15 Main Board Replacement, Bottom Casing: шаг 1, изображение 2 из 2
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    Спросите у FixBot
    Добавить комментарий
  2. EasySMX X15 Main Board Replacement, Battery: шаг 2, изображение 1 из 3 EasySMX X15 Main Board Replacement, Battery: шаг 2, изображение 2 из 3 EasySMX X15 Main Board Replacement, Battery: шаг 2, изображение 3 из 3
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    Спросите у FixBot
  3. EasySMX X15 Main Board Replacement: шаг 3, изображение 1 из 1
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    Спросите у FixBot
  4. EasySMX X15 Main Board Replacement, Main Board: шаг 4, изображение 1 из 1
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
    Спросите у FixBot
  5. EasySMX X15 Main Board Replacement: шаг 5, изображение 1 из 1
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
    Спросите у FixBot
Заключение
ShawnDetiveaux
Участник с: 09/09/24
646 Репутация
Автор 4 руководств
Команда
Austin Community College, Team 7-3, Watkins Fall 2024 Участник Austin Community College, Team 7-3, Watkins Fall 2024
AUSTINCC-WATKINS-F24S7G3
3 членов
Автор 7 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 39
За всё время: 412
