Eee Pad Transformer Prime TF201 Screen Replacement
Выберете то, что вам нужно
    1. Eee Pad Transformer Prime TF201 Screen Replacement, Opening Your Device: шаг 1, изображение 1 из 1
      • Power down your device.
      • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
      Спросите у FixBot
      Добавить комментарий
    2. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 2, изображение 1 из 3 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 2, изображение 2 из 3 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 2, изображение 3 из 3
      • Insert the plastic opening tool into the seam near the corner of the device.
      • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
      • It is normal to hear snaps as the spring clips holding the screen in place are released.
      • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
      Спросите у FixBot
    3. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 3, изображение 1 из 3 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 3, изображение 2 из 3 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 3, изображение 3 из 3
      • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
      • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
      • Safely place the device back on the table by laying the screen face down.
      • There will be some slight overlapping of the back of the case over the screen.
      Спросите у FixBot
    4. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 4, изображение 1 из 2 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 4, изображение 2 из 2
      • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
      • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
      Спросите у FixBot
    5. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 5, изображение 1 из 1
      • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
      • Repeat the previous process to remove the other ribbon cable.
      Спросите у FixBot
    6. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 6, изображение 1 из 1
      • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
      • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
      • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
      Спросите у FixBot
    1. Eee Pad Transformer Prime TF201 Screen Replacement, Screen: шаг 7, изображение 1 из 2 Eee Pad Transformer Prime TF201 Screen Replacement, Screen: шаг 7, изображение 2 из 2
      • Remove the six FH-00 2.2mm screws using the Phillips #00 screwdriver.
      • Start heating up the iOpeners now.
      Спросите у FixBot
    2. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 8, изображение 1 из 2 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 8, изображение 2 из 2
      • Place the iOpeners on the edges of the tablet and let sit for 2-5 minutes
      • Remove the iOpeners and repeat on the other side of the tablet
      Спросите у FixBot
    3. Eee Pad Transformer Prime TF201 Screen Replacement: шаг 9, изображение 1 из 2 Eee Pad Transformer Prime TF201 Screen Replacement: шаг 9, изображение 2 из 2
      • Slowly pry open the tablet using the plastic opening tool.
      • Place small suction cup on the screen and pull apart slowly to separate screen
      • Be careful not to jerk the screen apart, as this may cause unnecessary damage to the screen or the LCD.
      Спросите у FixBot
Заключение
To reassemble your device, apply glue to the screen and press it to the LCD, then follow these instructions in reverse order.
David Garcia
Участник с: 10/06/16
322 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 10-1, Livingston Fall 2016 Участник Cal Poly, Team 10-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G1
2 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 33
За всё время: 2,085
