Eightarc Fusion USB Cable Replacement
Выберете то, что вам нужно
  1. Eightarc Fusion USB Cable Replacement, USB Cable: шаг 1, изображение 1 из 2 Eightarc Fusion USB Cable Replacement, USB Cable: шаг 1, изображение 2 из 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Спросите у FixBot
    Добавить комментарий
  2. Eightarc Fusion USB Cable Replacement: шаг 2, изображение 1 из 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Спросите у FixBot
  3. Eightarc Fusion USB Cable Replacement: шаг 3, изображение 1 из 1
    • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
    • Be sure to be gentle and not snap the plastic flap in half.
    Спросите у FixBot
  4. Eightarc Fusion USB Cable Replacement: шаг 4, изображение 1 из 1
    • Slide USB cable up from the plastic barrier casing.
    Спросите у FixBot
  5. Eightarc Fusion USB Cable Replacement: шаг 5, изображение 1 из 3 Eightarc Fusion USB Cable Replacement: шаг 5, изображение 2 из 3 Eightarc Fusion USB Cable Replacement: шаг 5, изображение 3 из 3
    • The USB cord is connected to the logic board by a plastic plug with five wires.
    • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
    • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
    • Remove USB cable from device.
    Спросите у FixBot
Заключение
Dana
Участник с: 02/01/15
141 Репутация
1 руководство автора
Команда
Cal Poly, Team 17-35, Amido Winter 2015 Участник Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 членов
Автор 5 руководств
1 Комментарий к руководству
Where do I get the USB wire?
desmond.bouey1 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 39
За всё время: 1,249
