Ematic EGQ307 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Ematic EGQ307 Front Facing Camera Replacement, Front Facing Camera: шаг 1, изображение 1 из 1
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
    Спросите у FixBot
    Добавить комментарий
  2. Ematic EGQ307 Front Facing Camera Replacement: шаг 2, изображение 1 из 2 Ematic EGQ307 Front Facing Camera Replacement: шаг 2, изображение 2 из 2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
    Спросите у FixBot
  3. Ematic EGQ307 Front Facing Camera Replacement: шаг 3, изображение 1 из 1
    • Once you pry off the plastic backing, you will expose the battery and the motherboard.
    Спросите у FixBot
  4. Ematic EGQ307 Front Facing Camera Replacement: шаг 4, изображение 1 из 2 Ematic EGQ307 Front Facing Camera Replacement: шаг 4, изображение 2 из 2
    • carefully pry off the plastic backing, remove the tape over the camera.
    • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
    Спросите у FixBot
  5. Ematic EGQ307 Front Facing Camera Replacement: шаг 5, изображение 1 из 2 Ematic EGQ307 Front Facing Camera Replacement: шаг 5, изображение 2 из 2
    • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
    • Gently lift up the black lever that’s holding the camera ribbon in place using the spudger tools.
    • Once lever is lifted up, remove camera from device; and it is ready to be replaced.
    Спросите у FixBot
Заключение
Jonathan Scinto
Участник с: 07/21/15
530 Репутация
Автор 4 руководств
Команда
Eastern Washington University, Team 1-1, Rowley SU 2015 Участник Eastern Washington University, Team 1-1, Rowley SU 2015
EWU-ROWLEY-SU15S1G1
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 21
За всё время: 578
