Ematic Genesis Speaker Replacement
Выберете то, что вам нужно
  1. Ematic Genesis Speaker Replacement, Ematic Genesis Casing: шаг 1, изображение 1 из 3 Ematic Genesis Speaker Replacement, Ematic Genesis Casing: шаг 1, изображение 2 из 3 Ematic Genesis Speaker Replacement, Ematic Genesis Casing: шаг 1, изображение 3 из 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    Спросите у FixBot
    Добавить комментарий
  2. Ematic Genesis Speaker Replacement: шаг 2, изображение 1 из 3 Ematic Genesis Speaker Replacement: шаг 2, изображение 2 из 3 Ematic Genesis Speaker Replacement: шаг 2, изображение 3 из 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    Спросите у FixBot
  3. Ematic Genesis Speaker Replacement: шаг 3, изображение 1 из 1
    • Remove back plate from screen plate and lay both down flat next to each other.
    Спросите у FixBot
  4. Ematic Genesis Speaker Replacement, Speaker: шаг 4, изображение 1 из 1
    • Once panels are separated, disconnect speaker wires from motherboard.
    • Make sure device is completely turned off before doing this to avoid a potential electric shock.
    Спросите у FixBot
  5. Ematic Genesis Speaker Replacement: шаг 5, изображение 1 из 2 Ematic Genesis Speaker Replacement: шаг 5, изображение 2 из 2
    • Insert the flat end of the spudger between the casing and the speaker. Push inwards to pry the speaker from the casing.
    Спросите у FixBot
Заключение
Justin Rohrman
Участник с: 03/23/15
745 Репутация
Автор 6 руководств
Команда
Baylor, Team 4-3, Williams Spring 2015 Участник Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 членов
Автор 12 руководств
1 Комментарий к руководству
This help us alot, thanks for posting troubleshooting
wikirichard - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 20
За всё время: 454
