Введение
The side button array consists of the volume button, power button, M button and H button. The side button array is connected to the motherboard with a ribbon wire and to the front case with 3 screws. It is simple to remove and replace.
Выберете то, что вам нужно
Carefully remove the speakers from the rear panel.
Pull the speakers off of the rear panel.
Remove the 3 Phillips #00 4.5 mm screws from the side button array.
Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
Remove the ribbon wire from the ribbon wire port on the motherboard.
Еще один человек закончил это руководство.
