Epson PowerLite 77c Fan Replacement
Выберете то, что вам нужно
    1. Epson PowerLite 77c Fan Replacement, Lamp: шаг 1, изображение 1 из 1
      • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
      Спросите у FixBot
      Добавить комментарий
    2. Epson PowerLite 77c Fan Replacement: шаг 2, изображение 1 из 1
      • Slide the cover toward you, then lift it to remove it.
      Спросите у FixBot
    3. Epson PowerLite 77c Fan Replacement: шаг 3, изображение 1 из 2 Epson PowerLite 77c Fan Replacement: шаг 3, изображение 2 из 2
      • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
      • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
      • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
      Спросите у FixBot
    1. Epson PowerLite 77c Fan Replacement, Fan: шаг 4, изображение 1 из 1
      • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
      • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
      • Lift the top panel up.
      • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
      Спросите у FixBot
    2. Epson PowerLite 77c Fan Replacement: шаг 5, изображение 1 из 2 Epson PowerLite 77c Fan Replacement: шаг 5, изображение 2 из 2
      • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
      • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
      • Remove the top panel.
      Спросите у FixBot
    3. Epson PowerLite 77c Fan Replacement: шаг 6, изображение 1 из 1
      • Use a Phillips #0 screwdriver to remove the two 5.0 mm screws.
      Спросите у FixBot
    4. Epson PowerLite 77c Fan Replacement: шаг 7, изображение 1 из 2 Epson PowerLite 77c Fan Replacement: шаг 7, изображение 2 из 2
      • Remove the one 5.0 mm screw on the right side of the gap with a Phillips #0 screwdriver.
      • Remove the one 5.0 mm screw on the left side of the gap with a Phillips #0 screwdriver.
      Спросите у FixBot
    5. Epson PowerLite 77c Fan Replacement: шаг 8, изображение 1 из 1
      • On the right side of the motherboard, grip the plug labeled "PWR-FAN" and pull straight up to detach the fan from the motherboard.
      Спросите у FixBot
    6. Epson PowerLite 77c Fan Replacement: шаг 9, изображение 1 из 2 Epson PowerLite 77c Fan Replacement: шаг 9, изображение 2 из 2
      • Grip the fan and lift it up and out.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Xandher Thao
Участник с: 02/08/22
161 Репутация
1 руководство автора
Команда
Western Carolina University, Team 1-6, Virtue Spring 2022 Участник Western Carolina University, Team 1-6, Virtue Spring 2022
WCU-VIRTUE-S22S1G6
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 379
