Введение
Use this guide to replace the lamp in your Epson PowerLite S4 projector. Over time, projector lamps dim or burn out, affecting image quality. Replacing the lamp is essential for restoring brightness and ensuring optimal performance. This simple repair requires minimal tools, such as a screwdriver, and can be done by users with no prior technical experience.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove one screw to the right of the ports.
2 человек успешно провели ремонт по этому руководству.
