Eton FRX3 Solar Panel Replacement
Выберете то, что вам нужно
    1. Eton FRX3 Solar Panel Replacement, Rechargeable Battery Pack: шаг 1, изображение 1 из 1
      • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
      Спросите у FixBot
      Добавить комментарий
    2. Eton FRX3 Solar Panel Replacement: шаг 2, изображение 1 из 1
      • Disconnect the battery pack wires from the device and remove the battery pack.
      Спросите у FixBot
    1. Eton FRX3 Solar Panel Replacement, Case Assembly: шаг 3, изображение 1 из 1
      • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
      Спросите у FixBot
    2. Eton FRX3 Solar Panel Replacement: шаг 4, изображение 1 из 1
      • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
      Спросите у FixBot
    3. Eton FRX3 Solar Panel Replacement: шаг 5, изображение 1 из 1
      • Remove the two Phillips #00 screws located in the center of the back of the device.
      • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
      Спросите у FixBot
    4. Eton FRX3 Solar Panel Replacement: шаг 6, изображение 1 из 1
      • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
      • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
      Спросите у FixBot
    5. Eton FRX3 Solar Panel Replacement: шаг 7, изображение 1 из 1
      • Pull the two halves of the device's case apart.
      • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
      Спросите у FixBot
    1. Eton FRX3 Solar Panel Replacement, Solar Panel: шаг 8, изображение 1 из 1
      • The solar panel is connected to the motherboard through a simple socket, just pull up to unplug.
      Спросите у FixBot
    2. Eton FRX3 Solar Panel Replacement: шаг 9, изображение 1 из 1
      • The solar panel is not glued or soldered in place, you can simply lift the panel straight up from it’s seating to remove.
      Спросите у FixBot
Заключение
Jose Mendieta
Участник с: 02/10/16
255 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-6, Nance Spring 2016 Участник USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 членов
Автор 26 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 35
За всё время: 862
