Eton FRX3 Volume Dial Replacement
Выберете то, что вам нужно
    1. Eton FRX3 Volume Dial Replacement, Rechargeable Battery Pack: шаг 1, изображение 1 из 1
      • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
      Спросите у FixBot
      Добавить комментарий
    2. Eton FRX3 Volume Dial Replacement: шаг 2, изображение 1 из 1
      • Disconnect the battery pack wires from the device and remove the battery pack.
      Спросите у FixBot
    1. Eton FRX3 Volume Dial Replacement, Case Assembly: шаг 3, изображение 1 из 1
      • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
      Спросите у FixBot
    2. Eton FRX3 Volume Dial Replacement: шаг 4, изображение 1 из 1
      • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
      Спросите у FixBot
    3. Eton FRX3 Volume Dial Replacement: шаг 5, изображение 1 из 1
      • Remove the two Phillips #00 screws located in the center of the back of the device.
      • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
      Спросите у FixBot
    4. Eton FRX3 Volume Dial Replacement: шаг 6, изображение 1 из 1
      • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
      • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
      Спросите у FixBot
    5. Eton FRX3 Volume Dial Replacement: шаг 7, изображение 1 из 1
      • Pull the two halves of the device's case apart.
      • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
      Спросите у FixBot
    1. Eton FRX3 Volume Dial Replacement, Volume Dial: шаг 8, изображение 1 из 1
      • Unplug the socket connection from the I/O board as shown in the image.
      Спросите у FixBot
    2. Eton FRX3 Volume Dial Replacement: шаг 9, изображение 1 из 1
      • Remove the two 1 cm Philips #0 screws that secure the tuning dial panel to the device case.
      Спросите у FixBot
    3. Eton FRX3 Volume Dial Replacement: шаг 10, изображение 1 из 1
      • Gently lift the dial upwards to remove it.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Jose Mendieta
Участник с: 02/10/16
255 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-6, Nance Spring 2016 Участник USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 членов
Автор 26 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 32
За всё время: 889
