Выберете то, что вам нужно
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
To reassemble your device follow the following instructions in reverse order
Особая благодарность этим переводчикам:
100%
irlanda помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
