Fellowes T7CM Trigger Assembly Replacement
Выберете то, что вам нужно
    1. Fellowes T7CM Trigger Assembly Replacement, Fellowes T7CM Casing and Trigger Replacement: шаг 1, изображение 1 из 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Спросите у FixBot
      Добавить комментарий
    2. Fellowes T7CM Trigger Assembly Replacement: шаг 2, изображение 1 из 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Спросите у FixBot
    3. Fellowes T7CM Trigger Assembly Replacement: шаг 3, изображение 1 из 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Спросите у FixBot
    4. Fellowes T7CM Trigger Assembly Replacement: шаг 4, изображение 1 из 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Спросите у FixBot
    1. Fellowes T7CM Trigger Assembly Replacement, Trigger Assembly: шаг 5, изображение 1 из 1
      • Remove the trigger assembly by gently twisting and pushing it.
      • The assembly should come off easily with little effort.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Michael Aldrich
Участник с: 10/12/16
686 Репутация
Автор 5 руководств
Команда
IUPUI, Team 2-2, Baechle Fall 2016 Участник IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 членов
Автор 16 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 14
За последние 30 дней: 49
За всё время: 3,312
