Fellowes T7CM Trigger Sensor Replacement
Выберете то, что вам нужно
    1. Fellowes T7CM Trigger Sensor Replacement, Fellowes T7CM Casing and Trigger Replacement: шаг 1, изображение 1 из 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Спросите у FixBot
      Добавить комментарий
    2. Fellowes T7CM Trigger Sensor Replacement: шаг 2, изображение 1 из 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Спросите у FixBot
    3. Fellowes T7CM Trigger Sensor Replacement: шаг 3, изображение 1 из 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Спросите у FixBot
    4. Fellowes T7CM Trigger Sensor Replacement: шаг 4, изображение 1 из 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Спросите у FixBot
    1. Fellowes T7CM Trigger Sensor Replacement, Main Power Cord: шаг 5, изображение 1 из 2 Fellowes T7CM Trigger Sensor Replacement, Main Power Cord: шаг 5, изображение 2 из 2
      • Remove the wire holder. This is a small screwed in piece of plastic which holds the wires in place. The screw length is 10 mm and the head diameter is 6 mm.
      Спросите у FixBot
    2. Fellowes T7CM Trigger Sensor Replacement: шаг 6, изображение 1 из 1
      • Remove the blade housing from the external case.
      • Remove the three screws from the blade housing. The screw length is 18 mm and the head diameter is 5 mm
      Спросите у FixBot
    3. Fellowes T7CM Trigger Sensor Replacement: шаг 7, изображение 1 из 1
      • Use Caution when lifting the blade housing from the casing.
      • Warning: Sharp Objects are now exposed.
      • Place the blade housing close to the case to ensure no damage occurs to the connected wires and that they remained attached to the casing.
      Спросите у FixBot
    4. Fellowes T7CM Trigger Sensor Replacement: шаг 8, изображение 1 из 1
      • Locate the main power cord.
      • Clip the wire and strip the remaining end of the wire. Twist the new cord together with the remaining old wire.
      • Use electrical tape in order to cover the wire splice.
      Спросите у FixBot
    1. Fellowes T7CM Trigger Sensor Replacement, Trigger Sensor: шаг 9, изображение 1 из 2 Fellowes T7CM Trigger Sensor Replacement, Trigger Sensor: шаг 9, изображение 2 из 2
      • Remove the screws holding the feeding sensor in place. The screw length is 10 mm and the head diameter is 6 mm.
      • Lift and remove the sensor.
      • Replace the faulty sensor with a new sensor.
      Спросите у FixBot
Заключение
Michael Aldrich
Участник с: 10/12/16
686 Репутация
Автор 5 руководств
Команда
IUPUI, Team 2-2, Baechle Fall 2016 Участник IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 членов
Автор 16 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 17
За последние 30 дней: 64
За всё время: 7,955
