Fluke 77 Series III Dial Replacement
Выберете то, что вам нужно
  1. Fluke 77 Series III Dial Replacement, Front Panel: шаг 1, изображение 1 из 1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
    Спросите у FixBot
    Добавить комментарий
  2. Fluke 77 Series III Dial Replacement: шаг 2, изображение 1 из 1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
    Спросите у FixBot
  3. Fluke 77 Series III Dial Replacement: шаг 3, изображение 1 из 2 Fluke 77 Series III Dial Replacement: шаг 3, изображение 2 из 2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
    Спросите у FixBot
  4. Fluke 77 Series III Dial Replacement, Dial: шаг 4, изображение 1 из 1
    • Hold front panel with both hands, with your thumbs on the dial axle. The dial axle is the metal rod that comes out from the middle of the white plastic rotating piece.
    • Firmly press down on the dial axle to separate the dial from the front panel.
    • If this is difficult to do with your hands, push the dial axle against something hard, like the edge of a table.
    Спросите у FixBot
  5. Fluke 77 Series III Dial Replacement: шаг 5, изображение 1 из 1
    • With the dial loosened, pull the white plastic rotating piece until it comes off the dial axle.
    Спросите у FixBot
  6. Fluke 77 Series III Dial Replacement: шаг 6, изображение 1 из 1
    • Finally, push again on the dial axle with your thumb while at the same time pulling the dial off the front panel with your other hand .
    Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Kishan Patel
Участник с: 01/31/14
752 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 2-10, Amido Winter 2014 Участник Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 66
За всё время: 3,442
