Front Inner Tube Replacement
  1. Front Inner Tube Replacement, Front Inner Tube: шаг 1, изображение 1 из 2 Front Inner Tube Replacement, Front Inner Tube: шаг 1, изображение 2 из 2
    • First, remove the front wheel from the frame by unscrewing the adjustable screw
    Спросите у FixBot
    Добавить комментарий
  2. Front Inner Tube Replacement: шаг 2, изображение 1 из 3 Front Inner Tube Replacement: шаг 2, изображение 2 из 3 Front Inner Tube Replacement: шаг 2, изображение 3 из 3
    • Next, wedge tire tool below the bike wheel, right above the rim.
    • Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
    • Following this, grab the 2nd tire tool and place it into the gap you have created.
    • Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
    Спросите у FixBot
  3. Front Inner Tube Replacement: шаг 3, изображение 1 из 2 Front Inner Tube Replacement: шаг 3, изображение 2 из 2
    • After removing the bike tire, locate the bike valve used to pump air into the tire.
    • Gently remove the inner tube starting with the area around the valve.
    • Make a note of where the hole for the valve is located on the bike rim, because that is where the next step begins.
    Спросите у FixBot
  4. Front Inner Tube Replacement: шаг 4, изображение 1 из 1
    • Pump a small amount of air into the new bike tube so that it is easier to work with.
    • Next, locate the hole in the bike rim and feed the valve through and into position.
    • Next, wrap the rest of the tubing over the rim comfortably, while making sure that no folds or creases form on the tube.
    Спросите у FixBot
  5. Front Inner Tube Replacement: шаг 5, изображение 1 из 2 Front Inner Tube Replacement: шаг 5, изображение 2 из 2
    • Finish by placing the bike tire back on the the frame, while making sure that no fold or creases form in the tube.
    • Lastly, pump air into the tire and remount onto bike frame.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions.
3 человек успешно провели ремонт по этому руководству.
Theo Tzeng
Участник с: 07/22/13
59 Репутация
1 руководство автора
Команда
UC Santa Barbara, Team 1-2, Bradley Spring 2013 Участник UC Santa Barbara, Team 1-2, Bradley Spring 2013
UCSB-BRADLEY-S13S1G2
4 членов
Автор 3 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 57
За последние 30 дней: 153
За всё время: 3,188
