Введение
Use this guide to remove and replace the motherboard within a Fugoo Style XL.
Выберете то, что вам нужно
Using your hand, gently lift the large plastic tab secured to the rubber holding.
After lifting the tab, slide the speaker out of its case.
Remove the 8 screws (4 on each side) that hold the covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
When the red bundled cable connectors are disconnected, set the outer casing aside.
Untangle any blue bundled cable connectors and gently remove them from the motherboard using a pair of tweezers.
Carefully untangle and remove the white bundled cable connectors from the motherboard.
Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
Using your hand, carefully remove the midwoofers.
Using a pair of tweezers, lift the padded holding that secures the ZIF connector to the motherboard. The connector will release from the motherboard once the padding is lifted.
Carefully lift the battery and motherboard unit halfway out of the casing. The motherboard is connected to the battery directly.
When the cable is disconnected, fully remove the motherboard and battery unit.
Remove the 3mm screws using a #2.0 Hex screwdriver. There are 4 of these screws (2 on each side) that connect the motherboard to the battery unit.
When the screws are removed, use an iFixit opening tool to remove the motherboard from the two clamps securing it to the battery pack.
Using tweezers or your hand, carefully disconnect the bundled cables connecting the battery to the motherboard.
Еще один человек закончил это руководство.
3 Комментарии к руководству
Where can I purchase a replacement mother board?
Are you allowed to tell us where you found a motherboard? I can not find one anywhere for my fugoo
A repair guy lost my charging board, is there a way I can bypass it? Or Where can I get a replacement?
