Введение
This guide shows how to replace a Fujifilm X30 lens that may be cracked or damaged.
Выберете то, что вам нужно
Turn the camera upside down.
Place your thumb on the switch, and slide it towards the center of the camera.
Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
Begin by removing the outside screws using a Phillips #000 Screwdriver:
Remove the three 3.6 mm silver screws located on the bottom of the camera.
Remove all four of the 4.7 mm screws from the sides of the camera.
Remove all screws listed below using a Phillips #000 Screwdriver:
Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
Gently pull off the back of the camera from the left side so that it is partially open.
Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
For all five indicated orange strips:
Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
For the final orange strip located behind the top strip:
Remove the two 3.4 mm screws at the bottom of the silver plate.
Peel back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
Peel back the copper plate.
Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 Screwdriver.
Lift the motherboard so it is out of your way to remove the lens.
Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 Screwdriver.
Pull the lens down so it can clear the silver tab.
Then push the lens with your index fingers from the front of the camera until it is removed.
4 человек успешно провели ремонт по этому руководству.
