Fujitsu Lifebook A6110 RAM Replacement
Выберете то, что вам нужно
  1. Fujitsu Lifebook A6110 RAM Replacement, Battery: шаг 1, изображение 1 из 2 Fujitsu Lifebook A6110 RAM Replacement, Battery: шаг 1, изображение 2 из 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
    Спросите у FixBot
    Добавить комментарий
  2. Fujitsu Lifebook A6110 RAM Replacement: шаг 2, изображение 1 из 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
    Спросите у FixBot
  3. Fujitsu Lifebook A6110 RAM Replacement, RAM: шаг 3, изображение 1 из 2 Fujitsu Lifebook A6110 RAM Replacement, RAM: шаг 3, изображение 2 из 2
    • The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
    • Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
    Спросите у FixBot
  4. Fujitsu Lifebook A6110 RAM Replacement: шаг 4, изображение 1 из 3 Fujitsu Lifebook A6110 RAM Replacement: шаг 4, изображение 2 из 3 Fujitsu Lifebook A6110 RAM Replacement: шаг 4, изображение 3 из 3
    • Slide the cover towards the screw, and then lift the cover upwards.
    Спросите у FixBot
  5. Fujitsu Lifebook A6110 RAM Replacement: шаг 5, изображение 1 из 2 Fujitsu Lifebook A6110 RAM Replacement: шаг 5, изображение 2 из 2
    • There are two RAM cards in this compartment. They look like small green plastic chips with black squares on each of them. These cards are beneath a thin plastic sheet that must be pulled out of the way.
    • Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
    • If done correctly, the RAM card will eject at a 45 degree angle.
    Спросите у FixBot
  6. Fujitsu Lifebook A6110 RAM Replacement: шаг 6, изображение 1 из 1
    • Pull the RAM card out while maintaining the 45 degree angle it ejected at.
    • When reassembling, the gold pins on the RAM card must match the corresponding pins found on the motherboard.
    • If you choose to replace the other RAM card, repeat the process in Step 5.
    Спросите у FixBot
Заключение
Cody Moniz
Участник с: 10/19/16
422 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Участник UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 30
За всё время: 1,334
