Введение
If the picture on the screen of the laptop is distorted or is blacked out then the screen may need to be replaced, this guide will show you how to remove the screen from the Fujitsu Lifebook S6120.
Выберете то, что вам нужно
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to disconnect the ribbon cable from the motherboard.
With the tweezers detach hinge cover cables from the motherboard.
Remove hinge cover.
Use tweezers to remove the wires from the Adapter.
Remove the 4mm screws from the laptop with a Philips head #0
Remove the 4.5mm screws on the back of the laptop with a Philips #0
Use tweezers to grab onto the lever to remove the chip from the motherboard.
Use the metal spudger to pry up the edge of the plastic casing up.
Remove the plastic frame from the screen.
