GE Front Load Washing Machine Not Draining - Drain Pump Replacement
Видеоинструкция
Эта инструкция была взята из видеоролика на YouTube.
Выберете то, что вам нужно
    • Check that the drain hose is not inserted too far into the standpipe.
    • Ensure the drain hose has no kinks or damage that might block water flow.
    • Pull the hose back slightly if it's pushed in too deep to avoid siphoning or backflow.
    Спросите у FixBot
    Добавить комментарий
    • Open the lower access area and remove the pump-filter cover at the bottom front of the washer.
    • Pull the plastic tray down to reveal the blue release knob on the pump filter.
    • Place a towel or tray underneath and slowly turn the knob counterclockwise to release water.
    • Use the knob to control the water flow until it fully drains from the pump housing.
    • Remove and inspect the filter for debris or obstructions and clean it thoroughly.
    Спросите у FixBot
    • Pull the dispenser drawer all the way out and press the rear tab to release it.
    • Remove the five screws in the dispenser housing with a suitable screwdriver.
    • A magnetic screwdriver helps if screws fall inside the housing.
    • Lift the left side of the console and push it right to free it from the washer.
    Спросите у FixBot
    • Remove the three small screws along the top of the washer behind the console area.
    • Slide the panel forward and lift it up to access the top of the machine.
    • Detach or reposition the short wire harness if needed to gain more access.
    Спросите у FixBot
    • Release the outer door-boot spring with a flat tool, then peel the boot away from the front panel.
    • Watch for sharp metal edges as you pull the gasket from the washer opening.
    • Remove the two screws holding the plastic door-lock trim on the right side.
    • Remove the additional two screws securing the door lock and lift its tab free.
    Спросите у FixBot
    • Remove the nine screws around the bulkhead, including the screw near the dispenser area.
    • Tilt the washer carefully if you must remove three bottom screws, using a stable support.
    • Slide the air baffle free by releasing its retention tabs after removing the middle screws.
    • Lift the bulkhead up and pull it forward slightly to separate it from the washer frame.
    • Unplug the door wire harness on the left side to remove the bulkhead completely.
    Спросите у FixBot
    • Make sure the washer is fully drained through the pump filter before removing the pump.
    • Use slip joint pliers to compress and slide the hose clamps back, then remove each hose.
    • Expect some residual water and place a towel underneath to contain spills.
    • Remove the two top screws securing the pump assembly with a short screwdriver.
    • Disconnect the wire harness on the pump before maneuvering the unit out of the machine.
    Спросите у FixBot
    • Check the rubber hoses for blockages before installing the replacement pump.
    • Reconnect the wiring to the new pump first while you have more space to maneuver.
    • Align the pump with the rubber grommets and press it forward to position the screw holes.
    • Secure the pump with the two screws, feeling for the threaded openings if working blind.
    • Reattach both hoses, ensuring the black hose notch is oriented correctly, then clamp them.
    Спросите у FixBot
    • Reconnect the left-side wire harness behind the bulkhead before reinstalling it.
    • Lift the bulkhead above the washer chassis and lower it onto its plastic mounts.
    • Reinsert the bulkhead screws, beginning at the outer edges and moving toward the center.
    • Guide the door boot fan assembly into its slots and secure it with the related screws.
    • Reattach the door lock properly, adding two screws, then replace the plastic facade.
    Спросите у FixBot
    • Press the door boot gasket back onto the metal lip around the front opening.
    • Stretch the door boot spring back into place using a door boot spring tool or zip ties if needed.
    • Slide the washer's top panel into position and secure it with the three mounting screws.
    • Hook the console onto the two large screws on the right and push left to lock it.
    • Hold the dispenser housing firmly while installing the five screws, with the two larger in the middle.
    • Insert the dispenser drawer fully and ensure it latches securely in place.
    Спросите у FixBot
    • Run a drain or spin cycle to confirm the washer now drains and spins properly.
    • Check diagnostic codes or measure control board output voltage if the issue persists.
    Спросите у FixBot
Заключение
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Участник с: 01/21/25
6 557 Репутация
Автор 224 руководств
1 Комментарий к руководству
It looks like you can do what you've posted without having to take off the top panel of the machine- My machine is stacked with the dryer above. Could the machine be taken apart and drain pump replaced without removing the top panel- i.e., not having to unstack the machines? Thank you!
Sara Levine Kornfield - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 132
За последние 30 дней: 702
За всё время: 6,977
