Введение
Addressing joystick wear or malfunction, this guide assists GameSir G7 SE owners in replacing their joystick modules. Common symptoms that necessitate this repair include drifting, sticking, or unresponsiveness, affecting game control accuracy.
Disconnect the controller from all power sources before beginning the repair to ensure safety. Troubleshooting page sections such as “Joystick Drift” or “Sticky Joystick” might offer additional insights before you start.
Выберете то, что вам нужно
Remove the faceplate by prying upwards with a plastic opening tool.
Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
6 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Where to get the replacement parts?
Where do you get the replacement parts from?
Guida inutile senza ricambio
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
