GameSir Nova 2 Lite Button Replacement
Выберете то, что вам нужно
  1. GameSir Nova 2 Lite Button Replacement, Battery: шаг 1, изображение 1 из 2 GameSir Nova 2 Lite Button Replacement, Battery: шаг 1, изображение 2 из 2
    • Before you take your controller apart make sure it is powered off by holding the power button down for 15 seconds until it stops blinking.
    • Use a Phillips #0 screwdriver to remove the four 8.5 mm screws from the bottom of the controller's casing.
  2. GameSir Nova 2 Lite Button Replacement: шаг 2, изображение 1 из 3 GameSir Nova 2 Lite Button Replacement: шаг 2, изображение 2 из 3 GameSir Nova 2 Lite Button Replacement: шаг 2, изображение 3 из 3
    • Insert an opening tool between the two halves to open the controller's casing.
    • You will feel several internal latches called “snap-fit connectors.”
    • Disconnect them by sliding the opening tool along the seam in the casing, applying continuous pressure.
    • Once you find a connector, apply increased pressure until you hear a snapping sound.
    • Repeat this process until all of the connectors are disconnected.
    • Separate the top and bottom of the controller case.
  3. GameSir Nova 2 Lite Button Replacement: шаг 3, изображение 1 из 2 GameSir Nova 2 Lite Button Replacement: шаг 3, изображение 2 из 2
    • Set aside the bottom half of the shell.
    • Position the controller so that the motherboard is visible.
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
  4. GameSir Nova 2 Lite Button Replacement: шаг 4, изображение 1 из 2 GameSir Nova 2 Lite Button Replacement: шаг 4, изображение 2 из 2
    • If the battery appears swollen follow this link.
    • The battery is held in place by double-sided adhesive.
    • Use a spudger to loosen the tape securing the battery.
    • Remove the battery from the controller.
  5. GameSir Nova 2 Lite Button Replacement, Rumble Motor: шаг 5, изображение 1 из 2 GameSir Nova 2 Lite Button Replacement, Rumble Motor: шаг 5, изображение 2 из 2
    • Push on alternating sides of the JST connector to release it from the socket on the circuit board.
  6. GameSir Nova 2 Lite Button Replacement: шаг 6, изображение 1 из 1
    • Pull the motor out of its socket.
    • Repeat the steps for the other rumble motor.
  7. GameSir Nova 2 Lite Button Replacement, Buttons: шаг 7, изображение 1 из 3 GameSir Nova 2 Lite Button Replacement, Buttons: шаг 7, изображение 2 из 3 GameSir Nova 2 Lite Button Replacement, Buttons: шаг 7, изображение 3 из 3
    • Use a Phillips #0 screwdriver to remove the six 5.7 mm screws securing the motherboard.
    • Separate the midframe that holds the motherboard from the outer shell.
  8. GameSir Nova 2 Lite Button Replacement: шаг 8, изображение 1 из 3 GameSir Nova 2 Lite Button Replacement: шаг 8, изображение 2 из 3 GameSir Nova 2 Lite Button Replacement: шаг 8, изображение 3 из 3
    • At this point the only thing holding the buttons in place is gravity.
    • Remove the buttons from the top case.
Заключение
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 человек успешно провели ремонт по этому руководству.
Jonathan McMillin
Участник с: 09/29/25
185 Репутация
1 руководство автора
Команда
Austin Community College, Team 10-2, Watkins Fall 2025 Участник Austin Community College, Team 10-2, Watkins Fall 2025
AUSTINCC-WATKINS-F25S10G2
4 членов
Автор 6 руководств
1 Комментарий к руководству
I .... where to find the ( new stick )for the controller Gamesir ?
Leandro Montiel - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 40
За последние 30 дней: 146
За всё время: 597
