Введение
To replace the screen in your device you will need a T4 Torx screwdriver, a metal spudger, a plastic spudger, and a replacement screen. Be sure to have a large workspace to avoid mishandling or damaging the device components.
Выберете то, что вам нужно
Use a T4 Torx screwdriver to remove the four 6.35mm screws that secure the rear case of the device.
Remove the back panel using the metal spudger tool.
Flip the device over with the screen facing upward and open the device.
Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
Lift the screen and orange ribbon away from the motherboard.
Еще один человек закончил это руководство.
