Введение
If you find yourself on this guide, it means your screen is frozen, unresponsive or has shut down. In that case, it might be time to replace your screen. With the 3 easy steps listed on this guide, you will have that done in no time! The best part about this step is that you don't need to keep track of any tiny screws. You are simply focusing on softening that glue to remove the screen.
Выберете то, что вам нужно
Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
Repeat this process a second to ensure that the glue is becoming loose.
Alternative: Use a heat gun or hair dryer to heat up the glue
