Введение
If your watch face is damaged, cracked, or chipped, you can learn how to replace it using this guide. This guide involves simply unscrewing screws from the watch face and carefully disconnecting the screen’s ribbon cable from the motherboard. You will need a T6 Torx screwdriver and a spudger.
Выберете то, что вам нужно
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
6 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
I have the same question.
How do you make sure ribbon connector is aligned correctly
I have Fennix3, replaced the battery with new one (tested the battery before fixing), however, after complete assembly the watch does not start up? any hints?
