Garmin Nuvi 65LM Screen Replacement
Выберете то, что вам нужно
    1. Garmin Nuvi 65LM Screen Replacement, Plastic device casing: шаг 1, изображение 1 из 2 Garmin Nuvi 65LM Screen Replacement, Plastic device casing: шаг 1, изображение 2 из 2
      • Place the device on a flat surface with the screen facing down.
      • Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
      Спросите у FixBot
      Добавить комментарий
    2. Garmin Nuvi 65LM Screen Replacement: шаг 2, изображение 1 из 2 Garmin Nuvi 65LM Screen Replacement: шаг 2, изображение 2 из 2
      • There is a ribbon cable that will still connect the front and back panels once they are pried part.
      • Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
      • Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
      Спросите у FixBot
    3. Garmin Nuvi 65LM Screen Replacement: шаг 3, изображение 1 из 3 Garmin Nuvi 65LM Screen Replacement: шаг 3, изображение 2 из 3 Garmin Nuvi 65LM Screen Replacement: шаг 3, изображение 3 из 3
      • Use a spudger to pop up the ZIF connector tab that fastens the ribbon cable to the motherboard.
      • Gently pull the front panel away and set it on your flat work surface.
      Спросите у FixBot
    1. Garmin Nuvi 65LM Screen Replacement, Screen: шаг 4, изображение 1 из 2 Garmin Nuvi 65LM Screen Replacement, Screen: шаг 4, изображение 2 из 2
      • Use the flat end the spudger to push back the casing clips that hold the screen onto the front casing.
      • Apply light pressure to the front of the screen as you push the casing clips back. This will keep the clips from clicking back into place.
      • Once all clips are pushed back, the screen will easily lift away from the front casing panel.
      Спросите у FixBot
Заключение
James Crocitto
Участник с: 04/23/15
125 Репутация
1 руководство автора
Команда
Cal Poly, Team 15-3, Amido Spring 2015 Участник Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 членов
Автор 12 руководств
1 Комментарий к руководству
Hi where I can get nuvi65lmt screen
ganesh bhattarai - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 2,353
