Введение
This guide shows the user how to properly remove the screen from the Gateway MS2370 Laptop.
Выберете то, что вам нужно
Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
