Выберете то, что вам нужно
Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
Remove 5 6.0 mm Phillip #00 screws from under cover.
Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
First flip open the flap covering the ribbon using a spudger or fingernail.
Second gently pull the ribbon away from the port.
Grasp the plastic placeholder firmly and slide it out of the computer.
When inserting replacement optical drive, use the port at the back left of the open space.
Еще один человек закончил это руководство.
